Handle Replacement on GE Microwave
I need to replace the handle on my GE microwave with the noted Model Number above. However, I can’t seem to find that exact model number in your data base. All that comes up is JVM1339BW02, b ut not 002. I have checked the number on the appliance several times and I know it is correct.
It is not a countetop device it is a cabinet mounted microwave so I am not sure that the parts in your data base for the countertop would work the same.
Do you think they will be ok to use?
Here is the handle which seems to be right, but not sure
http://www.appliancepartspros.com/part_details.aspx?part_id=2021171
thank you
Thank You very much
