he3t will not drain
I have a He3t washer I got the F02 code I did what the book said to do press cancel twice and the washer would drain. now the washer will not drain at all. I can hear the pump trying to pump it out. book does not help with this problem.
If the pump is operating correctly you probably have an obstruction. Take it apart and clean it out and see what happens.
