Help Diagnose Maytag insignia Washer problem
[SIZE=3]Maytag Washer model # MAV3757AWW insignia [/SIZE]
[SIZE=3] [/SIZE]
[SIZE=3]First noticed 2 of the 4 Agitator main blades are broken off? [/SIZE]
[SIZE=3] [/SIZE]
[SIZE=3]And the clothes are still quite wet. Like the spin dry cycle is not working? [/SIZE]
[SIZE=3] [/SIZE]
[SIZE=3]Than after I used a screw driver to by-pass the lid switch.[/SIZE]
[SIZE=3]And did a visual inspection of a full wash cycle.[/SIZE]
[SIZE=3]I found:[/SIZE]
[SIZE=3] [/SIZE]
[SIZE=3]In both the wash cycle and the rinse cycles.[/SIZE]
[SIZE=3]Things start out OK.[/SIZE]
[SIZE=3]But after about one minuet of normal agitating. The unit stops working normally. [/SIZE]
[SIZE=3]All the water is pumped out. [/SIZE]
[SIZE=3]And the agitator starts cycling back and forth with no water in the drum?[/SIZE]
[SIZE=3] [/SIZE]
[SIZE=3]I think this “no water” agitation is what broke the blades off the plastic Agitator.[/SIZE]
[SIZE=3] [/SIZE]
[SIZE=3]To make things worse, in the spin cycle.[/SIZE]
[SIZE=3] [/SIZE]
[SIZE=3]The drum starts and tries to spin. But before it is able to come up to full speed.[/SIZE]
[SIZE=3] [/SIZE]
[SIZE=3]The agitator again starts to cycle back and forth. Slowing the slowly spinning drum. [/SIZE]
[SIZE=3] [/SIZE]
[SIZE=3]Then the drum stops spinning and this. begins again. [/SIZE]
[SIZE=3]Just slapping against the still wet clothes.[/SIZE]
[SIZE=3]For the majority of the cycle. [/SIZE]
[SIZE=3] [/SIZE]
[SIZE=3] [/SIZE]
[SIZE=3]One of the web-sights where you pay for a diagnose. Is telling me the timer is bad.[/SIZE]
[SIZE=3]I just do not see that as the problem.[/SIZE]
[SIZE=3] [/SIZE]
[SIZE=3]It seems to be worse with a large load. [/SIZE]
[SIZE=3] [/SIZE]
[SIZE=3]Just feels like the motor is not spinning fast enough to force the trans all the way into spin mode. [/SIZE]
[SIZE=3] [/SIZE]
[SIZE=3]The auger will fight the drum getting completely in to spin step? [/SIZE]
[SIZE=3] [/SIZE]
[SIZE=3]Just not comfortable purchasing a timer without more diagnostic steps to confirm it is at fault. [/SIZE]
