*** HELP!! GE Dryer Doesn't Heat ***
I have been trying to repair a GE dryer that at first wouldn’t run. Power came on but timer counted down in seconds. I have replaced the Power board and now it runs but doesn’t heat. I have tested the Hight Temperature Thermostat and have continuity. I do NOT have continuity on the Inlet Safety Thermistor. I have jumped the Inlet Saftey to bypass by still get no heat. Also is there any specific order the Red and Orange wires connect to the High-Temperature Thermostat as I faild to look before I removed them for testing. I also have continuity on the Heating coil and all other sensors. The only one that seems not to register is the Inlet Safety on.
…HELP HELP HELP PLEASE:eek: …
Is this something no-one has had issues with before? Strange I get no replies…
