Help locating defrost time on refrigerator
I am having icing problems in my freezer. Continuity on heater is ok. I’m not sure how to check if thermostat is ok. I was going to try to manually advance the defrost timer but I cannot locate it. Can anyone help me locate it? Thanks!
It’s located under the freezer compartment, behind the grille panel (#23 in the drawing).http://www.appliancepartspros.com/partsearch/model.aspx?model_id=113493&diagram_id=271369#d271369
AP2111929
