Help my kenmore dishwasher has a little lock light on and it wont turn on
there is a little light on my dishwasher that looks like a lock, and its turned on and i cannot turn it on the only thing on is that light . I know there is a way to turn it off i just cant remember please help. thanks:confused:
:smiley: Hold the no heat dry for four seconds and the light should go out. If not you might have the same problem I have.
dishwasher
varcadipone,
If the controls did not unlock after you followed the dishwasher’s instructions then the problem is a bad control panel. If you need the right part number post the complete model number of the dishwasher and the color of the control panel.
You are going to need to open it up and check the thermal fuses/thermostats
This service manual will show you how
http://www.servicematters.com/maytag_library/docs/16023020.pdf
Let us know what you find out.
