Help Replacing Water Actuator
My water actuator broke and I am interested in replacing it but I am not sure what I have to do to get to the part. Can I get to it from the front through the dispenser or do I have to take inside of freezer door apart to change it out?
I have looked at front dispenser area and have found three screws at the bottom under drip pan but haven’t found anything around the top. So if I can go through the dispenser how do I take the dispenser out of the door?
If I have to take back of door apart do I need to replace the door seal or can I recycle the one I take off?
Any help will help.
Thank you,
Shalan
