Help with a repair question
I have an electric range over 10 years old. The oven temperature is off by 50 degree and when I turn the little knob to set the oven temperaure it jumps, when I set it to go to higher temperature it jumps back to lower temperature.
sounds like the problem is in your LED clock timer this part is quite expensive…
