Help with Dispenser problem
Hello- iwent on vacation and all was fine-- came back and the lever on my fridge doesnt work… has resistance like it should work but will not dispense wter or ice… icemaker is making ice and i have been changing the filter regularly… i had a problem fairly recently where the drain in the back was clogged with crap and i had to go in and clean that out but this is new to me… i read that it coulb be some solenoid in the back but id need more info on that - so if anybody out there has and ideas id greatly appreciate it…
thanks
Anybody???
— Begin quote from virg357;638161
Anybody???
I also need he;p with this. my firdgidaire will not dispense ice or water, adn the light on the door doesnt work. The ice maker does make ice. So nothing is frozen. Electrolux recomended part number "Frigidaire 5303918476 Defrost Control Kit for Refrigerator
So I bought this. I have not installed it yet. But in looking at the part is does not say it controls the dispenser. It controls the defroster adn cooling and stuff like that.
Just so happens i was offered a extended warranty about a month ago for 95 bux. I figured it would cost at least that to get it fixed so i bought it. The repair guy was here today (coincidence) and the lever works if u push it at the top left side of it and he thought it was just out of the track - turns out after he put it all back together it still only worked when push in this manner and doesnt work when you just try to use it "normally" - they are ordering me a new lever and hopefully this takes care of the issue. - Hope that is of some use to you.
thanks for your reply
