Hi Temp & Heat Dry lights Flashing
My dishwasher starts the the chosen cycle(doesn’t matter which one) and stops after about 2 minutes. The Hi Temp and Heat Dry Lights are flashing. I can hit cancel and it will pump the water back out and drain. I turned off the power for about 30 minutes, but did not change. Do I need a new control board?
