I broiled on Friday, with the door open, and on Monday the oven will not heat.
Dacor says the high limit needs to be reset by a service professional. Is there an outline posted somewhere on how to do this? I’d like to save the service charge if I can.
I found the reset button and reset the high limit. The oven is working fine.
You should not broil with the door open.
I have the same problem…did the same thing.
Where is the reset button?
