there is a high pitched whine during spin cycle, louder than normal, sounds like a jet engine
This is a Frigidaire made front loader and that noise means the rear tub bearing is failing and that means replacing the machine because that bearing is not a separable repair part. You have to replace the rear tub and that is too expensive to recommend doing.
