Hot air furnace problem.
This furnace is about 35 years old, original equipment, it came with the house.
The thermostat is a lot more recent, the gas valve thermocouple was replaced a couple of years ago.
SYMPTOMS:
The thermostat calls for heat, the main burner comes on, after a while the fan starts up, but after a few seconds it all shuts down and tries again in about half a minute. I have verified that the fan does actually spin.
IDEAS so far:
The gas valve, thermocouple, fan and main burner are probably OK.
I think there is "something" that is not acknowledging that the fan is spinning and pushing air. This might be an air flow sensor or a thermostatic switch, I can imagine designs that would use either.
sounds like your motor is interaly bad (thermal overload). most any HVAC store will carry a replacement. be sure to take the old one with to get a correct replacement. if it is heat only then use the low speed. if it is heating and cooling then use low for heat and high for cooling. sorry i did not post sooner getting ready for summer at work :smiley:
— Begin quote from #1 tech;16846
Thanks for your reply.
It was indeed the fan motor, which I diagnosed without any help from APP.
BTW, are you an appliancepartspro employee ?
For anyone else who gets down this path;
At some point it occurred to me that, but for the new switch, the motor was hooked pretty much directly across 110 VAC. Since I had already replaced that switch …hmmm, kinda/gotta be the motor, so I did in fact wire it directly across 110 VAC (with the shutdown switch set to OFF) and sure enough I got the same symptoms. The whole lower blower unit is mounted on rails that slide out after removing a couple of small retaining screws. The squirrel cage is mounted to the (1/2 inch diameter) shaft with a set screw to the milled flat, the motor is mounted to the opposite side of the housing with 3 bolts to arms that are held to the motor with a band. All of this is quite intuitive once you have it all out. The 3 arms and retaining band had to be transfered to the new motor, of course I took care to be sure that I got it on STRAIGHT, tight and as close as I could to the same distance from the motor face as it was on the old one. I took the old motor with me and picked what little brain I could find in the local sales counter staff. Well, it came with a schematic anyway. The new motor came with a longer shaft, which didn’t matter because it just sticks farther into the fan cavity. I also turned around the 4 thin screws that run through the motor and hold the end plates on, to get their excess length away from the face of the motor where it MIGHT have mattered.
I now (for 2 days) have a very quiet and seemingly efficient heating system. It cycles more evenly, I suspect partly the new motor and partly the cleaning that I did are responsible for this.
About $200 total for switch and motor, the neighbor paid some $5500 to replace his about 5 years ago (same symptoms), but I only found that out yesterday (-:
What to do with the $5300 I saved ?
I’ll think of SOMETHING I’m sure, some of it should probably go to converting it to pilotless ignition (hot surface), something I’ve thought about every few years as the co$t of natural gas has continued to rise.
no i am not … just a HVAC tech who thought he could help out … if i was you i would look into changeing your unit over to a newer more effecent unit … if you look on the ID plate on the furnace it should tell you input and output of you furnace … judgeing from the age i would say it is no more than 80% … they now sell 90+ units which you can get to work with a heatpump … by doing this you can cut your heating costs by a very large amount … i have seen saveings of 2/3 of the yearly cost … plus it would add a/c in the summer … if you would care for ferther advice i would be happy to help … i also have some plans for a quick and easy solar window box that a person could bulid and helps dramaticly with engery cost
If I could swap out the burner & ignition system for a higher efficiency unit that would be fine. If I had to replace the whole standing unit that would be impractical. Just getting a new unit in and the old unit out would require the moving of too much "stuff", walls, etc.
I could get 50 or 60 pound sub-assemblies about the size of the blower unit in there without too much trouble, but not a whole cabinet.
If there isn’t a "guts replacement/upgrade kit", maybe there should be.
What might be causing the squealing noise on our Maytag Gas Dryer?
Would it happen to be that the Roller Bracket and/or Cylinder Roller are shot?
FYI, the noise has gotten increasingly worse over the course of the last month or so. It used to go away after the machine warmed up…now it is a constant noise.
Most commonly on these dryers it’sd the rollers or possibly the seals.
Here’s the parts breakdown. http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5177422
Nat
Low pitch "rumbling noise generally indicates support rollers. High pitch usually points to belt or idler pulley. Metallic "scratching" sound indicates a bad felt seal and/or worn glide bearings.
After error message and oven not working…
We have replaced the control panel and the latch becuase the repair man said it would fix it.
Then all the buttons worked except the "start" button (pad).
He came out and said to order a new switch membrane. We just installed it and the only button not working is the START.
Any help…what controls the start pad???
Here is the tech sheet
http://www.servicematters.com/docs/wiring/Tech%20Sheet%20-%208302067.pdf
If you mean that the start button does not work in any mode then try disconnecting/reconnecting the plugs at the control board.
Try setting the cavity size.
If the start button just will not operate the oven elements, could be the thermal fuse is blown
— Begin quote from christina_williams;851621
Hi… Proper & regular maintenance is a must to keep your furnace in proper working order. Monthly replacement of the filter in your furnace is one of the most important things you can do to extend the life and efficiency of your furnace. So, for this you have to go for a professional Furnace Repair service provider.
REALLY ?
Six YEARS later and all you can contribute is the standard noise from the generic owners manual ?
It worked FINE for 35 years, WITHOUT any so called "service"
a PART wore out, it was replaced,
it has worked FINE for 6 more years, WITHOUT further so called "service".
Evidently I do NOT need a "Professional Furnace Repair Service" - and I seriously doubt that many other people do either.
A SIMPLE, a VERY simple DIY repair of a household item.
"Professional furnace repair service provider" indeed.
