I have a hot, burning smell coming from the motor area of my washer. It also froze up and wouldn’t work again until I cooled it off with a fan (I took the front panel off). First, there was a crackle as it started to spin, then a puff of smoke from the motor. I started it again and it completed the spin cycle just fine, although still a smell. I lifted it up and found the belts to be intact. I suspect that I need to replace the motor…do you agree? I’m not sure if the smell is from the motor itself, or from the belts. Also, if I replace motor, should I replace the belts at the same time? Thanks.
Related topics
Motor smells as if burning | 3 | 1879 | July 24, 2011 | |
maytag waser motor burning smell | 5 | 5814 | February 6, 2009 | |
Maytag Performa Washer Smoking | 3 | 3334 | February 2, 2013 | |
Maytag washer overheating | 0 | 2749 | July 16, 2008 | |
Maytag washer smells burnt | 3 | 2023 | February 21, 2011 |
