Hotpoint aint so hot
Hello All,
I have a pretty old hotpoint (RB757GT1AD) and the day I left the oven on over night and my problem started. When i turn on the breaker the oven has a PF error code. I think its an error code. Then when the oven is set to off it will begin heating on it own. Ill turn it to 400 degrees and the oven on light will come on an right after the preheated light will come on like it ready to bake. Or at other times the oven on light will not come on and the preheated light will just flash. Its like its got a mind of it own. Ive already replaced the heating element thinking thats what it was. Thank you for you help
[SIZE=3]It sound like it almost got to be the main control (clock) but it is possible it is the sensor. If you have an ohmmeter check the sensor it should read 1000 ohms at room temperature. If not replace it. Hope this helps! [/SIZE]
[SIZE=3][/SIZE]
http://www.appliance-repair-it.com/range-repair.html
Maybe I should of stated this but Im a first time homeowner and novice oven repair man. Which sensor and where do i find it?
[SIZE=3]There is a sensor that sticks into the back of the oven. Here is a link to the part with a picture [/SIZE]
http://www.appliancepartspros.com/part_details.aspx?part_id=2023335&pn_=AP2023335
Here is a site with troubleshooting help that you may find useful
http://www.applianceaid.com/erange.html
We try to start the dryer, seems like the motor does not have enough power to turn drum, especially when we put wet clothes in.
We held the stop button in(which is on the door frame) with tape so we could turn the drum manually when the door is open, to start cycle.
At first it helped to start the drum.
Now it is harder to start and is getting more difficult to start .
Does the motor get weak over time?
If so can the motor be replaced and is it worth spending the money to fix it?
What would it cost with shipping to ship to Bridgewater, Ma 02324
Or could there be something else besides the motor to cause this problem?
Thank You
Jim
jdoteri@aol.com
Here are your parts breakdown
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=le7153wm
Yes it can.
[COLOR="Blue"]If so can the motor be replaced and is it worth spending the money to fix it?
What would it cost with shipping to ship to Bridgewater, Ma 02324[/COLOR]
Whether it is worth it or not depends on what shape the dryer is in.
See the parts breakdown and then give AppliancePartsPros a call.
It looks like a replacement motor may not be available for this unit.
I do not work for them so do not have the above info.
Check to see if you can get a motor. if not then you will need to buy a new unit.
If yes, then I would open the unit up and check all moving parts, the front glides, the belt, seals etc. for wear and bearing slop. Odds are good that you may need additional parts so the cost may be higher than just a motor.
You might as well do an overhaul while you have it opened up.
Also remove the motor from the unit before ordering one. Many units use a screw on blower wheel which often seizes onto the motor shaft and has to be broken to remove the motor. So you may also have to order a blower wheel increasing your costs.
Before any of the above I would check that the drum rotates fairly easily.
You may want to try this on a couple other units to get a feel for it.
Also try rotating it with some downward pressure on the drum. Perhaps you will get lucky and only the front glides have to be replaced (too much drag on the motor). Though usually you will hear metal on metal when they go.
