Hotpoint oven -new control board wires dont match
Got the new control board (WB27K10027), but no instructions for installation. The old board had 5 wires to it, the new one has 6. Don’t want to blow the new board, but I am lost as to what goes where.
you will notice the relay recessed male spade terminals on the new board are labeled for specific function. Some of those terminals are blocked off. Just look closely at the new part. There should be 1 terminal to bake(yellow), 1 to broil(purp/blu), a terminal labelled A/C in, and COM . I found on two of these boards the common(WHT.) and a/c in(RED) are mis-labled. I wired originally per board label and was only getting 120 to element. By swapping the red(L1) to the (COM) that allows 240 to flow. Please correct me if wrong, but bad mistake by manufacturer.
Thanks for your thoughts on the subject of mis-labeled wires. Obviously, I have since moved forward in the 2 years since my post, but I am glad to know I was not the only one thrown by this issue.
