[SIZE=4]I have a Hotpoint HSS25IFMD WW side by side Frig/Freezer. The freezer coil does not appear to defrost. Every two or three weeks I have to manually defrost it. I have replaced the Defrost heater element, the thermistor, and the Main Circuit board. [/SIZE]
[SIZE=4]Two questions: [/SIZE]
[SIZE=4]1) What else can be wrong? [/SIZE]
[SIZE=4]2) How do I test the Defrost cycle so I can see the element get hot? [/SIZE]
You may have a bad evaporator thermistor. Check its resistance per your service sheet, or go to the "sticky" above "GE (GS and HS refrigerators) for thermister common resistances. You can check right at the Ji connector on the motherboard per your data sheet, or the data given in the sticky.
If ok, remove the motherboard 4 pin power connector, notice which pins are labeled "line and defr.) and place a jumper across the same connector pins.Then plug in the fridg. If freezer is cold, it should defrost, you can check with an amprobe. If not, you have to check the freezer for the bad component.
It looks like water will run in the ice bucket after you hear the water valve turn off for the ice maker. Is it the solnoid valve leaking by after the water tray is full and it runs over? Where is the valve that needs to be replaced?
