Dishes (esp. upper rack) not getting clean. I removed the lower spray arm and found a lot of residue on the inside of the separator screen. I took the pump outlet off, then tried to remove the impeller to get at the separator. I put a 1" box wrench on the impeller and tried to turn the screw with a 1/4" socket, but couldn’t get it to budge, and started rounding it off in the socket. What size screw head is that, and does it loosen counter-clockwise? I can’t see any other way of getting at the separator assembly. Thanks.
Related topics
Rotator arm won't, rotate that is. | 0 | 3895 | September 1, 2007 | |
Noisy Pump, Impeller Now Broken? | 2 | 5076 | August 8, 2007 | |
whirlpool dw filter clogs, pump pressure | 7 | 14400 | February 11, 2010 | |
whirlpool pump impeller | 0 | 1374 | January 10, 2009 | |
disassembling dishwasher pump | 1 | 1407 | October 3, 2008 |
