How can I turn it OFF!!!
After using my stove yesterday, my front right burner will not turn off unless I unplug it. Its stuck on high. Being that tomorrow is Thanksgiving, Im not sure what to do. All help will be appreciated. Happy Thanksgiving everyone
The stove on this range has the electronic surface burners controls and the power board (#97 on the diagram).
The problem most likely is a shorted relay on the power board which provides power to this burner heating element. The solution is to replace the power board. As a temporary fix you have to located the wire which goes from the power board to the heating element on this burner and disconnect it. It must be insulated.
Here are the breakdown diagrams and http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5155268
You may want to contact Frigidaire
http://www.recallowl.com/Consumer+Recalls/Household+Products/Frigidaire+and+Kenmore+Smoothtop+Electric+Ranges+Recalled+Due+to+Fire+Hazard
