If Anyone Knows How To Remove The Heating Element From This Dishwasher Please Email Me Back With Directions.
Remove the lower panel, on the RT. side of the unit there are 2 nuts screwed onto the heater where it sticks through the tub. Kill the power, and take it apart. Do you know that its BAD???
how do you remove the white bults under neath the dishwasher in order to replace the heating element?
Remove the wires from the element and unscrew the the white plastic NUTS, Are you SURE that you NEED to remove it??? I really think that maybe you would be better off hiring a PRO to look at it for you.
I just bought a used thermador oven, but had to dismantle it to remove it from the third floor. I was carefull to mark most everything that I disconnected. There are 2 blue wires in the back that are not marked and dont semm to have a home. These 2 wires come out of the wiring harness together with 1 more blue wire and a yellow wire that go to the lower heating element. Any ideas?
found the connectors!!
