I have a Caloric Dish washer that is leaking water down the motor shaft. I have the motor out of the machine and half torn down. I need to get at the seal under the impeller but the impeller wont come off. the impeller is shaped like a nut on top, but I dont know if it unscrews or just slides up the shaft. I have tried both, but it wont move…is there something I’m doing wrong? Or is there a trick to the removal, I don’t want to break it…as the unit is about 25 years old (but still works great). Thanks
According to the Appliance Parts Pros database the impeller and seal kit for your dishwasher is on back order but it is still available.
- The part number for the impeller and seal kit is AP146496
I would recommend to call the customer service.
Here are the break down diagrams for the Caloric dishwasher http://www.appliancepartspros.com/partsearch/model.aspx?diagram_id=837999&&model_id=1966
For future reference, I use a sharp wood chisel to bust the old impeller off.
Hope I’m not too late here, although replacing this dishwasher is not a bad idea
This Caloric dishwasher was actually made by D & M (Frigidaire). While getting this impeller kit under the "Caloric" brand is pretty much impossible, it is readily available under the Frigidaire brand and we have hundreds in stock.
](http://www.appliancepartspros.com/part_details.aspx?part_id=2558048"]Impeller kit for DUS204-19[/URL] (instructions included)
[URL="http://www.appliancepartspros.com/part_details.aspx?part_id=2558048)
