I am frustrated. I know that I need to take the back off of my Kenmore Elite dryer. I have taken all of the screws out of the back but cannot get the back plate off. Can anyone tell me what I am doing wrong? I need to get in to check why I have no heat in the dryer.
You cannot get anywhere messing with the back. Everything is accessed from the front on this dryer:
[LEFT]Here is a pic of a princess dryer. This dryer by the way cannot be accessed from the [/LEFT]
[LEFT]rear at all. You pop the bottom flap springclips to access the heater and limits.[/LEFT]
[LEFT]The idea being convience of maintenence.[/LEFT]
[LEFT][DOT](http://sites.google.com/site/sublimeappliancerepair/washer-will-not-spin/agitator-woes/dryer-will-not-work/how-do-i-get-inside-my-dryer/gas-dryer-quits-heating/more-gas-dryer-enlightenment/gallery-of-dryer-parts-locations-and-diagrams/frigidaire-gibson-kelvanator-dryer-101/kenmore-whirlpool-englis-roper-dryer-notes/Princess%20dryer%20setup.jpg?attredirects=0"][/URL][/LEFT]
[LEFT]This dryer has more than one fuse.[/LEFT]
[LEFT]Note the location of the various fuses. Some folk call this the DOT dryer.[/LEFT]
[LEFT]Dryer of tomorrow. I call it the P. I .T .A. dryer. Go figure.[/LEFT]
[LEFT]To get inside this one you flip the controls like a direct drive top load washer [/LEFT]
[LEFT]You remove 3 hex head screws and slide the top towards you.[/LEFT]
[LEFT]You back off or remove some screws below the door, remove the door springs[/LEFT]
[LEFT]and then remove the screws up top that hold the inner panel to the frame.[/LEFT]
[LEFT]This dryer has 4 wheels, 2 in front and 2 in back. The Idler is located to the[/LEFT]
[LEFT] left and has to be routed blind with your arms.[/LEFT]
[LEFT]This dryer has a moisture sensing wire that attaches right beside the filter.[/LEFT]
[LEFT] It pays to know this because inevitably that dang wire will be a[/LEFT]
[LEFT] problem if you do not make a note of where it goes when removing the front.
