How to correctly replace bearings and slides/guides
it is squeaking like crazy and it’s coming from the front bearing support. I’m told i should do the back at the same time…
So i know all the parts i need to get. they front front support bearing, the read drum bearing kit, the dryer drum felt seal, 2 front drum support bearing glides, and 2 bearing slides for the front.
Question is… is there any how to on replacing these?
