http://www.meetoobridal.com/bridesmaid-dresses_c1121.html-You cannot beat the mermaid style bridal gown for drama, elegance, & sensuality. It is a style that always stays in fashion because of how great it makes a woman look & feel. In case you need to be drop dead pretty on your wedding day, then definitely give the mermaid shape a try.
http://www.promgarment.com/-So, an evening dress & a cocktail dress are similar in a way that they are dresses made of high-end, sometimes luxury fabrics, but, in plenty of ways, that is where the similarity ends. Each is worn for a different occasion, falls to a different length & is complemented with different accessories. Cocktail dresses are a small more casual than evening dresses.Fabric–As for the fabrics, dresses & formal dresses are fundamentally the same. Satin, taffeta & organza go well with any gowns. But materials can differ. Historically, evening gown or dress is made of heavier materials like velvet, silk, taffeta while dress is made of a mix of feather-weight silk or wool, a high-quality blend of synthetics & the above materials, but always never pure cotton (then it would be a sundress). Also the cut can be different. thing that stands out as an evening dress is the wide-shoulder cut while one-shoulder or demurely-cut halter can signify the cocktail dress.
http://www.bagshopmall.com/-For a neat, uncluttered look, select a column dress produced from satin. They look like liquid one time the dress moves. Another way to glisten is by wearing a dress covered with mirrored glass or sequins. When strapless styles possess a heavily embellished top and an unadorned skirt, it creates an eye-pleasing contrast. Panels of overlays are featured on prom dresses this season. Some only appear to be transparent, while others actually are see-through. They could be exactly the same color as the dress or a flesh tone. To produce additional excitement, sequins, beads or lace may be additional on top belonging to the overlays.
http://www.sharonmall.com/v-neck-wedding-dresses_c1135.html-As the name suggests, the mermaid wedding gown has similarities with forms of the siren. So, the mermaid tails are seen in this type. The dress has of plenty of features to increase the knee or slightly below or above the knee together. It can basically be seen as a modified version. Petite ladies appear much higher than the dress of the situation, all the attention on the general appearance & kind of his superb extract.
http://www.weddingtoga.com/ball-gown-prom-dresses_c1101.html-Apart from the strapless and strapped ones, single strap prom dresses also have its market. It is full of modern tincture and make you looks more asymmetrical. The design of the dresses has a flirty look beside the elegance, grace and charm it brings out. Moreover, single strap dresses also tends to make you more mature and appealing than the strapless ones.
