Cannot locate manual. Need to find out how to get to the pump.
Insert a screw driver in the gap between the top and the front near the edges and that will release clips that hold the front to the cabinet. This will give you access to the pump.
A putty knife used 4inches in between the top and the front panel will release the panel clips. The front panel will then hinge forward and then pick up out of the bottom tabs.
