confused on 3-wire cord hookup to terminal on maytag dryer .power cord is not color coded?
— Begin quote from starcraft1;117546
If you’ve bought one of the flat grey colored cords. The middle wire on the cord goes onto the center post of the terminal block on the dryer, and each one of the outer wires goes onto the outer posts of the dryer terminal block. Doesn’t matter which outer wire goes on which outer post.
Subject unit does n0t function on"Select Clean"
Mechanical lock for door also does not lock oven door.
All other functions are OK
Errors are E1 - F5 on the digital read out
This is a duplicated thread.
