I’m trying to figure out how to remove the agitator from my Kenmore 11022952100 top loader. Can anyone help please?
I was able to pop off the top fabric softener piece. I was then expecting to see a nut to loosen, but all I see down there is the top-side of what appears to be a threaded rod or something. How do I proceed?
— Begin quote from this_is_nascar;743190
Looks like, from a video I just watched, that I need to use a 1/2" socket driver as the tool to remove this.
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=11022952100
If you go to the Searrs site they will have an actual parts breakdown which they like to keep in house. It may help you see how yours goes together.
Click on the following picture a new page will open with a Q&A.
Also watch the video. It is for the agitator dogs but does show how to remove the agitator.
AP3119063
Thanks. Not sure what makes you think I’m trying to replace the agitator dogs, but thanks anyway. In addition, that video does not apply to my model of machine. As I previously mentioned, it turns out I need to use a 1/2" socket extension to remove the agitator, not a 7/16 inch socket as shown in this video.
Sorry but I did not see your last couple posts as the site had not updated on my computer and your posts were close in time to my reply.
I did not think you needed to replace the dogs but it’s video had how to remove the agitator.
Good luck with your repair.
— Begin quote from denman;743222
Thanks, but like I said. My agitator removes differently than what’s in the video.
