I need to check and maybe replace the door hinges on this range. How do I get the hinges out?
Thanks.
Mike
Thanks.
Mike
— Begin quote from mharrison;293904
Thanks.
Mike
Mike,
This should get you through the repair.
Good Luck,
[FONT=Helvetica-Bold][COLOR=#231f20][FONT=Helvetica-Bold][COLOR=#231f20][LEFT]Oven Door Hinge[/LEFT]
[/COLOR][/FONT][/COLOR][/FONT][SIZE=2][FONT=Helvetica-Bold][SIZE=2][COLOR=#231f20][FONT=Helvetica-Bold][SIZE=2][COLOR=#231f20][LEFT]NOTE: [/SIZE][/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][FONT=Helvetica][SIZE=2][COLOR=#231f20][FONT=Helvetica][SIZE=2][COLOR=#231f20][FONT=Helvetica][SIZE=2][COLOR=#231f20]Removal of range from installation position is
required.
[FONT=Helvetica-Bold][SIZE=2][COLOR=#231f20][FONT=Helvetica-Bold][SIZE=2][COLOR=#231f20][FONT=Helvetica-Bold][SIZE=2][COLOR=#231f20][LEFT]Door Removal[/LEFT]
[/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][FONT=Helvetica][SIZE=2][COLOR=#231f20][FONT=Helvetica][SIZE=2][COLOR=#231f20][FONT=Helvetica][SIZE=2][COLOR=#231f20][LEFT]• Open door to stop position (approximately 4"), then
grasp both sides of the door and lift up off hinges.
• Lay door on a protected surface, liner side up.[/LEFT]
• Close door hinges completely to avoid personal injury
[FONT=Helvetica-Bold][COLOR=#231f20][FONT=Helvetica-Bold][COLOR=#231f20][LEFT]Smoothtop Removal[/LEFT]
[/COLOR][/FONT][/COLOR][/FONT][FONT=Helvetica][SIZE=2][COLOR=#231f20][FONT=Helvetica][SIZE=2][COLOR=#231f20][FONT=Helvetica][SIZE=2][COLOR=#231f20][LEFT]1. Disconnect power before servicing.
2. Remove screws securing assembly to frame.[/LEFT]
[/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][SIZE=2][FONT=Helvetica-Bold][SIZE=2][COLOR=#231f20][FONT=Helvetica-Bold][SIZE=2][COLOR=#231f20][LEFT]NOTE: [/SIZE][/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][FONT=Helvetica][SIZE=2][COLOR=#231f20][FONT=Helvetica][SIZE=2][COLOR=#231f20][FONT=Helvetica][SIZE=2][COLOR=#231f20]Open oven door to access screws.
3. Raise smoothtop slightly and move slightly forward.
4. With the smoothtop moved slightly forward, label and
disconnect wire harness.
5. Remove smoothtop and place in a protected area with
underside up.[/LEFT]
6. Reverse procedures to reassemble.
[/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT][/COLOR][/SIZE][/FONT]
