hOW TO REMOVE THE ICE DISPENSOR DOOR ASSEMBLY
I have leaks coming thru the ice dispenser door. I thought first was the ice container leaks but it is some thing else. The chute door to let the ice came thru has never close. Warm air gets inside and melt the ice. So I believe that’s the cause of leak.
This leads me to think that a spring is broken or no longer functional. I found the replacing spring for $5.52. But how can I remove this ice door to assess the repair? Replacing the spring?
