Howling
Machine is making a loud howling noise during operation. Chopper assy., or motor?
More likely the problem is a bad motor. Such motors are well known for bearing problems. The repair will be much more reliable if you replace the whole pump & motor assembly. It’s worth $30 difference in prices.
