I need some heat :)
Dryer will tumble but no heat is produced.
I left it on for a long time on accident on the mode press saver
It is super capacity sound silencer 314 HP motor
Lint is cleaned out.
Is it heating element, thermostat, or thermal fuse?
I think it is the fuse.
How do I troubleshoot and make sure?
Is a thermal limiter the same as a fuse? That was recommended to me by your site via email.
Just wanna make sure I order the right part.
Thanks!:slight_smile:
Hi.
Use the multimeter to check the continuity of the thermal limiter(fuse), thermostat and heating element.To access this parts remove the top.
The limiter [part]134120900[/part]
Thermostat [part]3204267[/part]
Heater assembly [part]131475320[/part]
Here are the breakdown diagrams and Upper Cabinet / Drum / Heater parts for Frigidaire GLET1031CS0 - AppliancePartsPros.com
Post the results.
Simon.
