Ok so My machine is working intermittently. I First suspecting the switches behind the latch. Both were engaging fine, so I thought that maybe one had gone bad. I hard-wired around them to test and still no luck so That obviously isn’t the problem. All connections on the timer seem good. The Timer dials all seem to run through their cycles properly. Sooo…the only solution i have right now is if it won’t work, I bang the front of the dishwasher around where the timer is located and sometimes, eventually it will start. What do you think? Bad internals on the timer?
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=hda2000z01ad
You have checked the door switch and the wiring so I agree with you that all that is left is the timer.
If you have the wiring diagram you could check it with a meter.
…and now it won’t drain, so Solenoid is acting up. Could be the result of the Timer being bad. I dunno.
.and now it won’t drain, so Solenoid is acting up. Could be the result of the Timer being bad. I dunno
Yes this also could be a timer problem.
You may want to pull the solenoid and check it for signs of overheating re: melted plastic or it’s plunger sticking. You may also have to replace it.
The way it is supposed to work is that the solenoid is only powered for 5 to 10 seconds then the water pressure hold the flapper valve/solenoid closed till it is empty.
If the timer messes up or it’s contacts stick the solenoid gets power for a longer time which causes it to overheat.
I would replace the timer.
Hi Guys and Gals,
I just purchased a replacement oven burner ignitor. The replacement unit came with bare wires and wire nuts. The original seems to have push in plugs at the end of the wires. Does anyone know if I simply cut and strip the wires and use the wire nuts to splice into the original plugs? Also, does it matter what wire goes where?
Thanks,
George
Hi everyone,
No need to respond to this issue. Since I posted I discovered that others had the same question. Followed their solutions and figured it out.
Thanks,
Just George
p.s. Have a Happy Thanksgiving
