Only crushed ice will come out even when you select cubed. Removed ice container and U shaped bracket that turns cork screw will only turn one way no matter which option (crushed or cubed) is chosen. If you manually turn U proper direction and select cubed, the motor will turn the proper way. When cubed is selected, there is a noise like a sticking solenoid. My question, what is the correct part # for the solenoid that changes the turning direction of the U that turns the cork screw? DO YOU THINK THIS IS MY PROBLEM?
Related topics
GE side by side only dispenses crushed ice | 3 | 14075 | January 13, 2010 | |
the Drive Auger on my Ice dispenser is loose | 2 | 2618 | August 31, 2010 | |
Dispenses crushed ice but not cubes | 4 | 3428 | August 18, 2013 | |
Crushed ice works but not cube | 2 | 935 | March 30, 2014 | |
Refrigerator dispensing crushed ice but not cubes | 4 | 4853 | July 18, 2012 |
