Ice dispenser
I do I remove the face plate on the freezer door for the ice dispenser
With a screwdriver underneath the cover you will see two square holes place a small blade driver in it and pop the clips then lift cover in an upwards motion.If you aren’t carefull you will break the tabs and the cover wont fir properly Why do you think you need to take it off?
There is another kit out and what it does is make the assy stronget they have a plastic tab holding a stainless pin on the flapper well if it gets just a little stuck or frozen shut when pressure is applied the tab breaks and the door cant be mounted so a metal plate with double swtic tape is put in placde where the tabs were One can use this kit back to 1997. there were a string of them made with real thin plastic and they were always breaking I thin it was around 04 or 05 when that was happening SoThats the kit I thought you had sorry
I can assure you it isn’t glued after the botom is free and separated the top will slip right off get the bottomfirst use a screwdriver the same width or smaller that the hole push and twist it will release the clip all the plastic tabs on the cover have hooks on theml
I finally put the the flapper door support and the flopper door…the hard way…but I did it…thanks a lot anyway. I will try what you suggest again for the future…thanks a million do appreciate all your help…have a nice day.
