My ice dispenser will not dispense the ice the auger motor is good tested it and it turns. Could it be the micro swith in the panel or the panel itself?
It can be a bad micro switch as well as a bad control board or wire harness. You have to take it apart and diagnose. Be advised that the power board for the is model is no longer available.
Here are the breakdown diagrams and http://www.appliancepartspros.com/partsearch/model.aspx?model_id=113686&diagram_id=335686
If it is the panel what next?
Then it has to be replaced.
