ice dispenser
My ice dispenser only dispenses crushed ice regardless of whether the swith is on crush or cube. I have replaced the switch but that did not solve the problem. Any suggestions?
— Begin quote from KenEvans;413009
Ken,
A couple of quick,easy checks first.
Can you here the shifter solenoid activate "snap" when you select "cubed" ice ?
If you do hear the solenoid, remove the ice bin, and check that the end of the shifter arm is inside the yoke assembly, when you re install the bin.
Check the wiring harness at the door hinge and makes sure there are no loose connections, or broken wires in the connectors.
Is this the switch assembly you replaced ?
[part]AP3965563[/part]
If not, and everything else checks OK, you’ll need to start there.
Good Luck,
I did replace that switch but it did not fix the problem. When I go from cube to crushed the only sound I hear is the switch snap noise. I do not hear any other noise at all.
