Ice in Bottom of LG Freezer Compartment
I have ice forming in the bottom of my LG refrigerator freezer compartment.
Seems its a common problem.
The freezer is on the bottom with a door that opens to the the side.
My understanding is the problem is more than likely to be a blocked drain pipe where the water should drain out into the drip pan which is at the bottom of the freezer section on the left hand side as you look at it from the front but on the outside of the freezer compartment.
My ? is the following:
Where is the exit inside the refrigerator/freezer for the water to drain through?
Once found what is the best way to clean/unfreeze it?
