Ice Maker Dissassembly
I am trying to repair the ICE Maker and cannot remove the front panel. I have replaced door gaskets in the past, and when you roll back the gasket on this Kitchenaid you do not find screws that normally are used to hold the gasket in place. It appears Kitchenaid uses a snapping type assmbly or a special tool. What is the trick in removing the Icemaker and door seals? Any help is appreciated. I beleive I need to replace AP2990966 and the hinge.
Front panel as in the part that is on the front of the freezer door?
If so then the trim just pops off from the front.
Look for a couple slots in the bottom that you can put a flate blade screwdriver into and pop it off.
It was moved from the kitchen to the garage and did not work there after. I then moved it on it’s side to my house several months ago. When turned on everything on the unit works except the internal fan, but when plugged to a different power source it does. The unit was not turned on immidiatly we waited about a week.
