Ice maker flapper door sticks open
How do I get into the mechanism that controls the ice maker door. When I remove the plastic water collection plate I don’t see any screws. Under that plate while it moves a small amount I don’t see how it would come out. Do I have to remove the inside door panel on this model. Thanks Martin
What is the trick to getting the touch pad off. feels as if something is holding it on Thanks Martin
Figured it out. The solenoid and shaft were a mess. Had to clean with sand paper. seem to work fine. Thanks Martin
