Ice Maker Leak
Ran out of ice yesterday. Ice tray was bone dry. Water dispenser continued to work properly. I checked the intake water line and discovered a slow leak where it connects to the refrigerator. I tightened the brass screw but still had the slow drip. The line is not cracked. Can anyone suggest a fix before I call for repairs?
open the freezer and find the dime sized tube that feeds the water into the icemaker - is that tube frozen solid? was the leak where the water line connects to the water valve or was the leak where the plastic line runs up the back of the fridge into the freezer?
Dime sized feeder tube was indeed frozen. I will thaw today w/hair dryer. The leak was where the plastic line meets the freezer. No cracks found in the line. Thanks for pointing me in the right direction. I’ll let you know if thawing solves the problem. Should I expect recurrence or might this have been a "one time" problem? We have had the refrigerator since 2001 without any problems.
the frozen filler tube indicates that the water valve doors are not closing all the way causing drops of water to drip down the fill tube slower than normal which is making it freeze in that tube 1 drop at a time. replacing the water valve will fix that problem. it was leaking at the connection by the freezer because that tube was frozen and the water had to go somewhere!
