ICE Maker loses power when cold.
Kitchen Aid KRSA25ILSS01
Hoping someone may have an idea on this one…I have the typical Whirlpool ice maker part number 2198597. It stopped making ice so I did some testing on it…
Resistance
L-H = 72.7
L-M = 77.0
V-N = 175.0
Volts
L & N = 0 V
T & H = 0 V
L & V = 0 V
With the ice maker removed I tested the wiring at female connector that connects to the ice maker.
W & B = 95V
B & G = 95V
So I came to the conclusion that the motor was bad and replaced it with a new Module Motor. I connected everything back up and did some checks
L & N = 95V
T & H = 95V
L & V = 95V
Put the unit back into the freezer and sat down waiting for the first drop of ice cubes. Sadly nothing was happening. Curious I pulled the ice maker from its mount and did a multimeter test while still connected.
L & N = 0V
T & H = 0V
L & V = 0v
I then ran a continuity test on the ice maker harness thinking there maybe a break in the wiring harness. All wires showed continuity between the two ends.
By this time the ice maker warmed up and thinking I had not made a proper connection re-connected it. I then performed a multimeter test and once again saw power at the various test points. Waited 15 minutes of being in the freezer and ran a multimeter test and the unit had no power again all readings were 0.
Did it one more time once the unit warmed up and reconnected power after 10 - 15 mins no power
Really appreciate any thoughts on what could be causing the ice maker to shut down when it gets cold.
Pj
