ice maker not making ice
after defrosting the refrigerator ICE MAKER is making ice only for one time
ice maker led light stays solid green
dual solanoide works fine
water line to ice maker has no ice
will somebody help on this issue?
thanks in advance
Turn the ice maker "off" for a minute. Turn it "on" and during the first 15 seconds push the feeler arm from the ‘out’ position to the "in" position and back again 3 times (3 times only) to enter the service diagnostic mode. It consists of a harvest cycle followed by a water fill (5.1 sec).
Post the results.
abadfish66 and Gene:confused:
will be give me the icemaker model no ?
which I mentioned in my previous post?
Gene gave the part no buton website no photo of product
so I want to confirm first that I am buying GE Ice Maker WR30X10061
Actually the new part# is WR30x10093, it should take you about 5 minutes to change it, just remove the 2 screws and unplug the wire plug. You do need to transfer to the new icemaker the fill tray and shield, you’ll see what I’m talking about when you get the new icemaker
abadfish66
thanks for your help
I put the new ice maker and working fine
any recall on this model or not?
will you help me on this ?
The auger in our icemaker (463409G039) is rusted. I have removed it from the icemaker bin (WR17X4310). I see that I can order the auger separately, but cannot get the ice crushing assembly off the old auger. I will probably need to order additional parts to complete this job. Can you tell me how to strip the auger?
Belts have broken to the washer but I don’t know how to replace them. Its confusing. A digram would help but i cant find one on the net anywhere. please help.
This is coming up as a direct drive washer. It does not have any belts.
Can you tell us what is wrong and why you think the belt(s) are broken?
Raj,
Wanted to ask how the new ice maker is working and if you have had any issues with it since you installed. I’m in a simialr situation with a GE IM-6 ice maker that has crapped out and looking to replace myself…
this is a washer /dryer stackable . the transmission is powered by drive belt the belt is broken. it will not strech over the pulleys very dificult to acces
— Begin quote from sidfink43;164102
this is model flxe52rbs7 frigidaire washer dryer stacker. the belt that
is broken drives the transmossion. the broken belt is laying in bottom of washer. i have the new belt but cannot get it to roll on as had been sugjested
thanks
