Ice maker not working
Ice make is not working. Water dispenser is working fine. The red light on the right side wall of freezer is blinking when door is open when I close the flipper on the left it goes off.
I tested the Ice make per what I learned in U-tube. I put a jumper cable in "T" & "H" ports and nothing happened. Then I connected "M" & "N" with jumper cable and the motor did not work. Then I took out the Ice maker and connected electricity directly to motor to make sure if the motor is bad but the motor started turning and it’s fine. Looks like the power to Ice Maker is switched OFF by some switch.
When I put back the Ice maker the motor did not complete the cycle and looks like no power is coming to Ice maker.
Please advice what can be the issue. Can this be the optic beam sensor?
