Ice maker is not working no water. I can hear what sounds a motor trying to turn. By replacing the control module will this fix it? I am a novice do it yourselfer but willing to try replace it on my own.
Frigidaire–the Water Is Not Dispensing
Fridgidaire No water filling . Tray is clear of any water and ice
My washer would operate fine most of the time. Periodically it would just click. Sometimes it took a few tries. Sometimes it took coming back later. The last few days it hasn’t started at all. In trying to get it to work the piece that locks the door shut was broken off. I’m wondering what all needs to be replaced and how high a skill level it would take.
That is a fairly easy repair, if you will click on your model number you will be taken to an exploded view of your machine. I am not sure what parts you need but you should be able to tell from the diagrams.
Good luck.
