Ice maker on unit quit. I replaced the water valve and it worked for a week or so but has quit again. The transmitter/receiver boards check out fine. If I fill the ice maker with water manually the ice maker will freeze the water and dispense the ice but will not refill. The water source is from a water well and I suspect maybe that the ice holder tray has some deposits on it that is blocking the signal to the water valve. Dose this make sense that this could happen? If so I should be able to clean the ice maker tray and it should work, right?
thanks for the advice.
