Ice Maker shows no power, light not on, no ice
The icemaker was working fine, we emptied the entire bucket for an outing when we came back found just a few cubes had been made and they were frozen into a sheet of ice about 1/2" thick in the tray. Shut off the ice maker, looked up the diagnostic test turned on the switch, no green light, pulled the connector, showing 19.57V across two of the four terminals, checked for water supply inlet, filter inlet, and inlet to the water valve all good. pulled the supply tube to the icemaker it is clear, no water beyond the valve. Any thoughts on how to proceed
