Ice maker -solid block of ice
My ice maker is creating a solid block of ice on the bottom 2/3 of the ice bin. The ice that is dumped into the bin on top is fine. The problem is the ice cubes that are in the lower half of the bin. They melt and freeze into a solid block.
I think my main door and flapper seals are closed/OK.
Is there any electronics behind the bin that could be heating up the bottom portion of the bin causing the ice to melt and re-freeze?
