ice maker will not work
it has ice in it
I have checked voltage at the plug and I do have voltage
what do you think the problem could be?
any help would greatly be appreciative
Thanks Derrick
Hi Derrick,
Open the freezer door, press in the emitter flapper door (on the left side) to unblock the optics beam and view the diagnostics "status" LED on the right side.
Post your findings.
Hi gene
when the flagging door is open there is a red blinking LED
when the flag door is closed the red LED stays on
Thanks so much for replying
Thanks Derrick
Thank you so much for your input
i was thinking that it might be the motor
I have another question I tore the ice maker apart
and i noticed a set of contacts that is controled by a white switch on the left side of the icemaker when you open the freezer door.
what does that actually do?
In the wiring harness which wires are the signal wires that actuates the water refill valve and how do you check the voltage?
again thanks for your in Gene
Derrick
This is probably the switch which operates with the water inlet valve.
Your question about voltage - I’m afraid I did not get it right. What did you mean?
Flashing Red light on Panel is Flashing Twice and my Ice Maker is not working. I have replaced the Water Vaule and the Mother board? It is not getting water up to the ice maker. What does the Red FlaSHING Code Mean??
