replaced water valve due to water filling ice tray twice. (fills, then minutes later it fills again.) overfilling and leaving a block of ice in ice container. checked pressure going to refrigerator 25+ lbs. Uninstalled maker an took apart . Checked ice tray for leaks an cracks saw none. Filled cube tray up with water to check for leaks,none. Is there an adjustment on motor/sensor to decrease water flow. or is a new ice maker in the works. This is a 8-cube tray,on French door, no ice chute on door. S/N jj0f4gbb5002212d
Related topics
Samsung Ice Maker | 1 | 1285 | May 31, 2011 | |
Samsung Ice Maker doesn't fill with water | 1 | 314 | May 8, 2022 | |
Ice Maker | 1 | 734 | June 24, 2013 | |
ice maker issues | 3 | 948 | December 4, 2011 | |
Samsung Ice Maker | 11 | 1886 | April 25, 2016 |
