Ice maker
Please help! My ice maker makes ice but it leaks water at the back in side of the freezer. Now it is running into the refrig and the crispper pans stay full of water. I have turned off the Ice maker ( raising the wire to stop the ice from making ) but the water is still going into the refrig. PLEASE HELP ME! Thank you for your time.
Cut off your water supply to the freezer, usually under the sink or a saddle valve in the line behind the freezer. Can you see exactly where water is coming from? The fill tube at the ice maker or the line where it goes into the freezer back. The water inlet valve could be stuck open.
